-   -   Laminate flooring in basement (http://www.diychatroom.com/f5/laminate-flooring-basement-73335/)
gdoucette 06-10-2010 11:06 AM
I'm in the process of finishing the basement in one of my houses. I have a 10x10 room which will be used as an office. The basement has never had moisture problems and the concrete floor in this room is very flat and smooth. I am wondering if is sufficient to simply lay foam underlay with vapor barrier on the concrete and then install flooring? or do I need something more? I need to do this as cost effectively as possible, so what are your thoughts?
canadaclub 06-10-2010 01:46 PM
No problem I can think of. Do it all the time.
flooringgirl 06-10-2010 09:01 PM
I agree, as long as you have the vapor barrier, you should be fine.
Tia
