laminate flooring for basement
allen and roth laminate flooring is it ok to put this in a split level basement should i use an underlayment
Never heard of it. Did you try going on there web site?
All the instrutions and limitations should be right there. You have to install it the way the company states, not how someone on line suggest or no warrenty. |
Allen and Roth..Lowes brand line |
Weens,
When you get around to reading the instructions you will learn; http://pdf.lowes.com/installationgui...36_install.pdf The concrete must be very flat and dry. You need to do a calcium chloride moisture test and pass it. You must install 6 mil vapor barrier, and you must install the recommended underlayment among many other details. Jaz |
| All times are GMT -4. The time now is 08:25 AM. |
