Laminate Flooring Around Curved Fireplace - Flooring - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 02:44 PM   #1
Laminate Flooring around Curved Fireplace
We have laid down some laminate flooring in the house and left some room between brick fireplace for expansion. What do I put down to hide the gap?
Laminate Flooring around Curved Fireplace-fireplace3.jpg   Laminate Flooring around Curved Fireplace-fireplace2.jpg
Dallas is offline   Reply With Quote
Old 12-21-2008, 11:09 PM   #2
Rewards Points: 2,906
The gap is prolly too wide for regular vinyl baseboard molding.
What do you think of the idea of installing some Johnsonite 3" Tightlock for Carpet (by putting flat head screws into plastic anchors set in the mortar joints of the brick) and then gluing some 3" Tightlock for Carpet Resilient flooring directly over the first vinyl baseboard, so that you can cover an 11/16 inch gap?
http://www.johnsonite.com/FlooringSy...4/Default.aspx
http://www.johnsonite.com/Portals/5/...eProfiles2.pdf
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 12-22-2008, 06:50 AM   #3
Rewards Points: 26
The only ideas i can think of is to either cut quarter round at angles like 22.5 or less to "round" the corner the best you can. You would have to glue the joints and then probably use construction adhesive to attach it to the brick. The other option would be to glue some solid oak peices together and make a template out of cardboard of the radius of the fireplace and trace that to the oak. Use a jig saw to cut out the shape and then use a router make your own quarter round. That would take some wood working skills but not that hard. Maybe someone else will have another idea or know of a product premaid for this. I just did a quick google and found this site http://flexibletrim.com/P_CurvedWalls.htm
ponch37300 is offline   Reply With Quote
Old 12-22-2008, 07:18 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Other option: Color Matched Caulking. Not the best, but option, but there it is....
Also: Obtain some flexible molding, cut it down to about base shoe dimensions. Paint it to match the color of the flooring...
- Build Well -
Old 12-22-2008, 07:26 PM   #5
Registered User
Termite's Avatar
Along the lines of what Atlantic said, you can get flexible sanded caulk that is made for tile jobs, but would closely match the mortar in the brick joints. It has sand in it, which gives it a mortar/grout appearance. Home centers have a small selection of colors, but tile specialty places will have dozens of shades for a very close match.
Old 12-23-2008, 03:41 AM   #6
Floorwizard's Avatar
you may be able to use rubber 1/4 round that is easy to bend and attach to the brick.
Floorwizard is offline   Reply With Quote
Old 02-22-2011, 05:18 PM   #7
Curved fireplace - what did you do?
I saw your post from 2008 (?) about your laminate flooring and curved fireplace. What did you finally decide to do and do you have any finished pictures?
We have a fireplace/hearth that looks just like that and we are in the process of installing solid hardwood floors. That fireplace is my obsession of the moment. How did you get the cuts so nice on the curve?
I thank you for any advice you can give!
MMurphy2001 is offline   Reply With Quote
Old 02-22-2011, 05:49 PM   #8
woodman58's Avatar
You can get vinyl 1/4 round from Lowes (sorry to put a store name out here. IT is made by Flexco if you know where else to get it). It comes in white, brown, and black. It will make a good curve.
woodman58 is offline   Reply With Quote
Old 02-22-2011, 11:04 PM   #9
Rewards Points: 200
Under cut the fireplace/hearth with a jam saw and slide the wood under the fireplace/hearth .
Finished product , no need for molding .
Floor Doc is offline   Reply With Quote
Old 03-01-2011, 01:47 AM   #10
Master of none
Look at 'PROFLEX'
I saw a sample of a product called Pro flex at the local building supply store. I was interested in applyinf casings around windows, but some had half circle tops. This stuff is supposed to be paintable or stainable like wood. I picked up a brochure and looking at it, there is a web site "@profilemouldings.com".
handy andy is offline   Reply With Quote
Laminate Flooring Question cacell Flooring 7 03-30-2017 08:01 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 09:01 AM
