Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2011, 03:08 AM   #1
Laminate Flooring
I'm going to install laminate flooring in much of my house. I've never done this before, so I have some 'dumb' questions.
First one: Is it usual to put a transom in each doorway leading from room to room, as was done in older homes, or would you just run the flooring continuously through the house?
Thanks...
Gary
Gary Sutherland is offline   Reply With Quote
Old 02-18-2011, 07:22 AM   #2
woodman58's Avatar
When laminate first came out it was common practice to put a transition in any doorway that was less than three feet wide. With the new core being more stable it is no longer necessary.
woodman58 is offline   Reply With Quote
Old 02-18-2011, 07:28 AM   #3
Rewards Points: 1,668
Just for future reference:
Transom: a bar of wood or stone across the top of a door or window, also a fixed window over a door or another window.
Threshold:
1. A piece of wood or stone placed beneath a door; a doorsill.
2. An entrance or a doorway.
Transition: To change from one thing to another (one kind of flooring, or level of flooring)
Look at:
http://www.woodfloorsonline.com/prod..._hardwood.html
Very good explanations of different situations with new floors, moldings, and transitions.
bob22 is offline   Reply With Quote
Old 02-18-2011, 07:54 AM   #4
Rewards Points: 200
Check the installation guidelines that come in the box., or contact their tech support .
Floor Doc is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 07:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
