Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 12:29 PM   #1
Question
laminate flooring
I am preparing to install a tile floor with a laminate backing. Has anyone done this using the moisture barrier? I am concerned that laying the floor on this will cause the floor to shift and the grout joints to crack. Also do you really need to use a specific grout. The Lowe's rep said you can use any grout and that the tile can be cut by using a good blade on a circular or table saw
gmsev is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 04:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
