Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 11:17 AM   #1
Laminate flooring
Hi
I'm trying to install laminate wooden flooring, 12mm thick. I've put the best quality underlay down on wooden floor which is level
However after putting down the fourth row everytime I knock at one end the other end comes out of place slightly so it's not completely tight.
Why does this occur? How can I prevent it
Please help.
alkil is offline   Reply With Quote
Old 12-26-2010, 11:22 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Is this an Armstrong floor? I've seen similar issues with their 12mm products. They use a drop together end joint that has no locking system. It tends to be a little loose and from what I've seen it can get worse over time and start to click. I don't like selling the stuff myself. Other brands have a plastic tab in the end joint that still allows for drop together end joint but they actually lock into place once they are dropped. I've only heard of one complaint on the Pergo brand of that system.
poppameth is offline   Reply With Quote
Old 12-26-2010, 11:43 AM   #3
No is an ultimate brand
It just doesn't seem to click together
They hav plastic in top and bottom ends but nothing on the sides
Do you think if o continue and complete the room the weight of the adjacent planks will keep things in place?
Also I've just read about "spacers" when installing laminates, how do these help, as I was planning to fit them all tight so they don't fall out of place
Thanks for the advice
Old 12-27-2010, 05:52 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Spacers are to keep the proper expansion joint around the walls. You generally leave a 1/4" gap between the wall and the laminate to allow for movement.
Can you get any photos of the gaping?
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 12:04 PM
