Old 09-29-2009, 03:44 PM   #1
Apprentice
UpComingBuilder's Avatar
Laminate Flooring
I am going to install laminate flooring in a kitchen.
My question is how do I rip the tiles off the floor? Floor chizel etc and what about the mortar underneath the tiles?
And once all of this is done, (I know that there is a concrete slab underneath) what if some spots are unlevel before I place the foam stuff that goes underneath the laminate?
>>SooN<<
UpComingBuilder is offline   Reply With Quote
Old 09-29-2009, 09:10 PM   #2
Apprentice
Laminate Flooring
Or maybe someone could help me with the steps?
When I take the tiles off how will I know if there is a vapor barrier?
I also read in a topic that you can use plastic for a vapor. What kind of plastic is it?
I also researched a vapor retarder. Where do I purhase that? Lowe's seems not to supply a vapor retarder. I installed a laminate floor in my house in a 14' x 28' room but the subfloor was plywood. I just don't want to make the floor buckle without using the right products.
>>SooN<<
Old 09-30-2009, 01:17 AM   #3
Floorwizard's Avatar
Laminate Flooring
first, let us know the manufacturer you are using.
6 mil poly film works great but the pad that comes with the floor may have it.
removing tile requires little more than a hammer and such.
if the floor is way out of level you may need to use a self leveler, or trowel the stuff on if it's not too bad.
read the manufacturers guidelines when it comes to flatness.
usually not more than 1/4 inch up or down in a 10 foot wingspan.
Floorwizard is offline   Reply With Quote
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
