-   -   Laminate Flooring (http://www.diychatroom.com/f5/laminate-flooring-34285/)
restomod69 12-23-2008 01:36 PM
Laminate Flooring
Hi everybody; My first time here. I recently retired and purchased a manufactured home. Built in 1994. 3 beds and 2 baths, with a woodburning fireplace. Pretty cool. I gutted almost everything inside and am now putting it all back together. Drywall,electrical, and paneling.
The house sits on cinder block piers approx. 4feet off a poured concrete slab, and a cinder block wall surrounds the whole house looking as if it had a block foundation. This house was delivered via expressway in two halfs. The joists are 2X6 16" on center in a metal frame work. The sub-floor is 3/4" particle board. It's straight and level as can be. So far I'm impressed with the joint.
I want to know if I should install 1/2" particle board over the 3/4" and start laying down my Quit Walk Floating Floor Underlayment and SHAW Glueless Laminate Flooring? Thank you, Restomod 69
jensenconstruction 12-23-2008 11:28 PM
The 1/2" is not needed. Go ahead and put down your underlayment and start installing the floor.
restomod69 12-24-2008 09:56 AM
Thank you Jensen Const. Will do....I'll put the money saved towards cabinets. I kinda thought it was over kill. TKS. restomod69
