Old 02-09-2013, 10:08 PM   #1
Laminate flooring on 2nd floor....vapor barrier?
I am installing laminate flooring on my whole 2nd floor
I guess a vapor barrier is not required, right?
french_guy is offline   Reply With Quote
Old 02-10-2013, 12:37 AM   #2
No, but if there's no built in padding on the back side of the flooring your going to have to lay that first.
Might want to read the box or go on line and read the manufactures install directions.
Old 02-10-2013, 07:55 AM   #3
Yes, there is a padding
And I am planing to put 1st a layer of Homasote 440 for sound insulation
http://www.homasote.com/products/440-Soundbarrier.aspx
I was also thinking to put that 1st (between plywood and Homasaote) but they told me it won't be very helpful since there is no air in-between
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
So i will probably go with the Homasote only......
Old 02-10-2013, 09:40 AM   #4
Before going foward on this figure out how your going to trim out where it meets the stairway. Last thing you want is a trip hazzard.
Old 02-10-2013, 09:45 AM   #5
Yes, there will be somehow a transition with the stair
I will redo the stairs with oak, not laminate
I think I can manage to have the last stair perfectly at the same level of the laminate..and for the transition strip, I will have to find a thin one.
Don't see what I can do else...
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 10:06 PM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
