Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 06:59 PM   #1
Rewards Points: 152
laminate flooring
I want to install laminate flooring in my basement. I was wondering, how thick is laminate flooring? I did some plumbing and Im not sure what my finish will be with the thickness of the laminate floor.
Also, i want to put some kind of underlayment on the laminate flooring, what is this underlayment called? Does this underlayment have some insulating factors? I want to have some kind of insulation under the flooring.
humberguy is offline   Reply With Quote
The Following User Says Thank You to humberguy For This Useful Post:
jponto07 (05-24-2014)
Old 05-18-2014, 07:09 PM   #2
Gymschu's Avatar
Rewards Points: 664
Most laminates are 7 mm to 12 mm thick so roughly a 1/4" give or take. Some have an underlayment attached others, require a separate underlayment to allow the floor to float.
I don't think there is much of an insulating factor with underlayment. Your biggest issue is having a moisture barrier between the concrete and the flooring. If you don't address that, your flooring will wick the moisture and crumble.
Hopefully, others come along with more suggestions.
Gymschu is online now   Reply With Quote
Old 05-18-2014, 08:08 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
Engineered flooring will have a better chance of survival in a basement.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-21-2014, 07:48 AM   #4
Laminated flooring is best to survive for years.
loganmuirden is offline   Reply With Quote
Old 05-21-2014, 08:53 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,480
Moisture migration is always a potential problem with basement flooring (even SOG sometimes).
First, evaluate as best as possible, your potential for moisture migration, through different climatic conditions, condition of your homes grading, type of soils, what you have encountered over time.
You can tape some clear 6 mill film to the floor and watch for moisture migration, check humidity levels, etc.
Then, basically you can not block successfully,.... you would like to provide an escape/ventilating option.... If you can't frame a subfloor....
There are some underlayments (I call them bubble-wrap) that actually provide a minor/miniscule ventilation out to your baseboards.
If it is a click/lock, that will allow migration escape through the click lock joints.
And your product quality will vary significantly.... some is almost cardboard (not really) that will deteriorate very quickly with moisture... others are more water resistant.
These are just general ideas.... I have very limited experience in below grade installs... (generally, I won't due them).
I'm most interested in some of our pro flooring men's best advice.
TIA
MTN REMODEL LLC is online now   Reply With Quote
Old 05-21-2014, 11:52 AM   #6
Rewards Points: 84
How can you even suggest that? Laminate has a particle board core. Moisture will destroy it. Engineered has either an MDF or plywood core. Both stand up to moisture better than particle board.
I have installed flooring since 1973. I have removed a ton of laminate that was destroyed by moisture as small as someone cleaning it with a Swiffer.
Old 05-24-2014, 07:22 AM   #7
I also agree that Laminate flooring is not something you want to put in an area that may get damp and humid! It does not like any moisture at all!
b75nweav is offline   Reply With Quote
Old 05-24-2014, 08:17 AM   #8
Rewards Points: 274
Laminate Flooring is the best solution for this.I strongly recommend that.
alexjoe is offline   Reply With Quote
Old 05-24-2014, 11:22 AM   #9
Rewards Points: 3,528
They are coming out of the woodwork today!!!!!
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
rusty baker (05-24-2014)
Old 05-24-2014, 11:36 AM   #10
Rewards Points: 84
Laminate falls apart with moisture.
Old 05-24-2014, 06:44 PM   #11
Rewards Points: 362
Someone with 450 postings advising laminate around moisture? yow!
ront02769 is online now   Reply With Quote
Old 05-24-2014, 06:59 PM   #12
NEW water resistant laminate PRODUCTS GUYS..... or vinyl tile that goes together and looks like laminate/eng wood.....
http://homerenovations.about.com/od/...ofLaminate.htm
Old 05-24-2014, 07:13 PM   #13
r0ckstarr's Avatar
Rewards Points: 2,012
Where to buy in the US?
http://www.aquastep.be/en/
r0ckstarr is online now   Reply With Quote
Old 05-31-2014, 08:13 PM   #14
Cool..
Old 06-01-2014, 08:45 AM   #15
Rewards Points: 236
i bought some $1.50 sf water resistant laminate for my temp kitchen floor. we have had a few small spills, and its just fine.
Fix'n it is offline   Reply With Quote
Laminate flooring in frame house goodag2 Flooring 3 12-09-2012 07:00 AM
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
