Old 02-15-2013, 08:32 AM   #1
laminate flooring
can i use a steam mop for laminate flooring?
momf is offline   Reply With Quote
Old 02-15-2013, 09:35 AM   #2
Pro Flooring Installer
rusty baker's Avatar
laminate flooring
No, the moisture may make the partcle board backing swell and/or fall apart.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 02-15-2013, 06:10 PM   #3
JetSwet's Avatar
laminate flooring
Ive used steam mop over my laminate for 2 years and had no issues, as long as your not soaking laminate you have to clean it some way imo.
JetSwet is offline   Reply With Quote
Old 02-17-2013, 04:13 PM   #4
laminate flooring
I used to tell my wife not to use the steam mop on the super cheap laminate in one of our bathrooms because I thought it would cause problems. She's ignored me for 5 years now and it still looks as good as it ever has.
I think as long as its hot enough to dry quickly it's probably ok.
dftc is offline   Reply With Quote
Old 02-17-2013, 05:43 PM   #5
747
registered
747's Avatar
laminate flooring
Yes put it on lowest setting. I actually have the shark steam mop like on tv. It works great. Lowest setting. Here is the one i have.
http://www.sharkclean.com/cgi-bin/li...sponsor=000006
747 is offline   Reply With Quote
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 10:06 PM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
