Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-02-2013, 05:47 PM   #1
laminate flooring
I am laying a pergo type flooring in about a 25 by 15 foot room, in smaller rooms ive never had a problem but with the longer rooms ive seen the boards start to seperate a little bit. I wanted to know it anyone has used and can recommend a glue I can use to help the pieces stay together a little better over time
clarc31 is offline   Reply With Quote
Old 01-02-2013, 05:58 PM   #2
Rewards Points: 12,840
I use a dab of the glue that's made for laminite floors, but only on the short butt joints.
Most often reasons laminite floors come apart are there not locked in all the way, when laying the pieces in place do not just insert them and try and lay them down all in one motion. Instead work them up and down getting closer to the subfloor each time to work it into the joint.
Someone nails the flooring to the subfloor or hits it when installing the 1/4 round, It can not be attached in any way to the subflooring.
Not enough gap left around the outside edges or around the doorways.
Old 01-02-2013, 05:58 PM   #3
Rewards Points: 264
Most laminate flooring does not require glue, and I don't think it would be a good idea to use it on the joints as it would probably be a huge mess of glue to clean up. Maybe consider engineered flooring. It floats just like laminate, yet it looks better, most can be refinished in the future and best of all unlike laminate it is real wood.
Awoodfloorguy is offline   Reply With Quote
Old 01-02-2013, 06:03 PM   #4
I shouldve been more clear, the butt joints are what im talking about, they dont lock into each other as much as they just kind of fit together
Old 01-02-2013, 06:05 PM   #5
http://www.amazon.com/QEP-1406-P-Ton...+Flooring+Glue
Most maufactures suggest using glue as well as a vaper barrier when laminites going over a slab subfloor.
Just do not glue it to the floor, just on the joints.
Old 01-10-2013, 08:58 AM   #6
I think some laminate flooring do not require glue because it would not be a good idea to use it on the joints cause it would result in a huge mess of glue to clean up...
CharmainPhilips is offline   Reply With Quote
Old 01-10-2013, 10:54 AM   #7
It's water based glue and just wipes right off with a damp rag.
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
