Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 02:35 PM   #1
laminate flooring
installing flooring but just realize there is an depth difference between stair railing and linen closet wall. how do i get flooring to line up properly?
anita2 is offline   Reply With Quote
Old 12-16-2012, 07:56 PM   #2
Rewards Points: 13,250
What's a stair railing have to do with flooring?
Laminites not the best choise for a second story.
No good way to end it where the stairs are without a trip hazard.
Also unless you used cork as an underlayment it's going to be a lot louder when walked on, down stairs.
Old 12-16-2012, 10:16 PM   #3
funfool's Avatar
Rewards Points: 534
Joe .... What!
funfool is offline   Reply With Quote
Old 12-17-2012, 09:49 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Need more info. Post pics, joe is right about laminate upstars and also not able to end it by stairs with out problems.
JetSwet is offline   Reply With Quote
Old 12-18-2012, 05:31 PM   #5
they make stair nosings for laminte , may be 1/8 to 3/16 or so higher obviously for overlap, which allows for movement. i always glue and nail nosing, dont hit laminate with either, andd then throw a small peice of trim under nosing for added support, we usually use a reducer that matches nosing to help supprt nosing.
Dantro is offline   Reply With Quote
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 06:57 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
