-   -   laminate flooring (http://www.diychatroom.com/f5/laminate-flooring-166619/)
anita2 12-16-2012 01:35 PM
laminate flooring
installing flooring but just realize there is an depth difference between stair railing and linen closet wall. how do i get flooring to line up properly?
joecaption 12-16-2012 06:56 PM
What's a stair railing have to do with flooring?
Laminites not the best choise for a second story.
No good way to end it where the stairs are without a trip hazard.
Also unless you used cork as an underlayment it's going to be a lot louder when walked on, down stairs.
funfool 12-16-2012 09:16 PM
Joe .... What!
JetSwet 12-17-2012 08:49 PM
Need more info. Post pics, joe is right about laminate upstars and also not able to end it by stairs with out problems.
Dantro 12-18-2012 04:31 PM
they make stair nosings for laminte , may be 1/8 to 3/16 or so higher obviously for overlap, which allows for movement. i always glue and nail nosing, dont hit laminate with either, andd then throw a small peice of trim under nosing for added support, we usually use a reducer that matches nosing to help supprt nosing.
