Old 12-07-2012, 08:09 PM   #1
Laminate Flooring
Well we lived in Apt: for 25yrs and are moving into our brand new house and my wife says let's lay some Laminate Flooring!! , So we are going to try to put Laminate Flooring in 2 bathrooms both '6x'7 and '7x'6.
What is the first step make a template? The only thing in there is a tub and cabinet in one the other has a cabinet and shower on the other the toilets are not install yet. We bought the Laminate , glue and something like a roller to get any air pockets out.
bote110 is offline   Reply With Quote
Old 12-07-2012, 09:56 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Laminate Flooring
Are you sure you mean laminate? It isn't glued and should not be put in a bathroom. Do you mean vinyl (linoleum)?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-07-2012, 10:24 PM   #3
Laminate Flooring
Yes! you are correct Rusty ,
That is what we are using Vinyl (Linoleum)thanks for the correction . The Laminate Wood Flooring is going into the 3 Bedrooms .
Old 12-08-2012, 08:51 AM   #4
Laminate Flooring
Going to need a toothed trowl to spread the glue. Should say right on the can which one to use.
Make sure you remove any 1/4 round. Under cut all door trim so the material can be slid in under it so the seam does not show.
Going to have to lay it even with the middle of the door opening and need some form of transition strip to cover the seam.
Make sure to remove the vanity or pedistal sink.
Remove the door so it does not keep getting in the way.
When you rough cut it make the cuts about 2" bigger then it needs to be and trim it once it's in place.
Old 12-08-2012, 06:28 PM   #5
Laminate Flooring
My wife and I tackle the Vinyl (Linoleum) in both bathrooms today . It looks alright for our first project together not bad good thing we are going to add trimmings around the floors edge . Now she wants to try the '10x'13 mud room. I have to take some pain pills tonight!! My knees and shoulders hurt! and that was only x2 '6x'7 bathrooms!!
Thanks for the tips
Old 12-08-2012, 07:11 PM   #6
Laminate Flooring
Thanks for the tips
YEA but it makes you feel good to know you did it, doesn't it?
The Following User Says Thank You to ToolSeeker For This Useful Post:
bote110 (12-08-2012)
Old 12-11-2012, 07:21 AM   #7
Laminate Flooring
My carpenter put in the finish baseboard and what a different look !!
Old 12-14-2012, 12:17 AM   #8
Laminate Flooring
What to do along the edge of the tub and shower in both bathrooms ?
should I add a bead of caulking ? can i add a quarter molding along the edge to seal the Linoleum
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
