-   -   Laminate Flooring (http://www.diychatroom.com/f5/laminate-flooring-165870/)
bote110 12-07-2012 07:09 PM
Laminate Flooring
Well we lived in Apt: for 25yrs and are moving into our brand new house and my wife says let's lay some Laminate Flooring!! , So we are going to try to put Laminate Flooring in 2 bathrooms both '6x'7 and '7x'6.
What is the first step make a template? The only thing in there is a tub and cabinet in one the other has a cabinet and shower on the other the toilets are not install yet. We bought the Laminate , glue and something like a roller to get any air pockets out.
rusty baker 12-07-2012 08:56 PM
Are you sure you mean laminate? It isn't glued and should not be put in a bathroom. Do you mean vinyl (linoleum)?
bote110 12-07-2012 09:24 PM
Yes! you are correct Rusty ,
That is what we are using Vinyl (Linoleum)thanks for the correction . The Laminate Wood Flooring is going into the 3 Bedrooms .
:thumbup:
joecaption 12-08-2012 07:51 AM
Going to need a toothed trowl to spread the glue. Should say right on the can which one to use.
Make sure you remove any 1/4 round. Under cut all door trim so the material can be slid in under it so the seam does not show.
Going to have to lay it even with the middle of the door opening and need some form of transition strip to cover the seam.
Make sure to remove the vanity or pedistal sink.
Remove the door so it does not keep getting in the way.
When you rough cut it make the cuts about 2" bigger then it needs to be and trim it once it's in place.
bote110 12-08-2012 05:28 PM
My wife and I tackle the Vinyl (Linoleum) in both bathrooms today . It looks alright for our first project together not bad good thing we are going to add trimmings around the floors edge . Now she wants to try the '10x'13 mud room. I have to take some pain pills tonight!! My knees and shoulders hurt! and that was only x2 '6x'7 bathrooms!!
Thanks for the tips
:gun_bandana:
ToolSeeker 12-08-2012 06:11 PM
Thanks for the tips
:gun_bandana:
YEA but it makes you feel good to know you did it, doesn't it?
bote110 12-11-2012 06:21 AM
My carpenter put in the finish baseboard and what a different look !!
bote110 12-13-2012 11:17 PM
What to do along the edge of the tub and shower in both bathrooms ?
should I add a bead of caulking ? can i add a quarter molding along the edge to seal the Linoleum
