Old 11-20-2012, 06:10 AM   #1
Laminate flooring
I had a shop/shed built in my backyard and I am turning it into a craft room. But I have run into a problem. All the supplies and furniture that is going in there is currently stored in my husbands garage. He is now insisting that we move it all into this shop. I plan on adding electricity, insulation, and wallboard. But I need to put the laminate flooring in before the wallboard goes up on the walls so I can move all my stuff out of his garage. Is it possible to put laminate flooring down before. The wallboard goes up on the walls?
Michelle
sspryte is offline   Reply With Quote
Old 11-20-2012, 06:38 AM   #2
Super Moderator
Laminate flooring
That is foolish----the dust and grit can get under the laminate ---and all over the new floor---rent a tent when you dry wall---move everything into there for the week it will take to drywall and add your floor and trim---
oh'mike is online now   Reply With Quote
Old 11-20-2012, 06:52 AM   #3
Laminate flooring
I know it is. But we are running short on funds. So no money right now to rent a tent. Doing this on a shoestring budget. I do not know what else to do. I can lay down drop cloths on the flooring so nothing happens to it while we drywall. So is it possible to put the laminate in without having drywall up?
Michelle
Old 11-20-2012, 06:57 AM   #4
Super Moderator
Laminate flooring
Yes, It will be more work---but sure if you can protect the floor well and tape the edges when you drywall--go for it---use craft paper to protect the floor---plastic might react with the laminate and cause discoloring----
Old 11-20-2012, 10:00 PM   #5
Laminate flooring
just wait to put down the laminate. put your stuff in the shed. when it comes time to do some work, do it on sunny days and move you stuff on onto the lawn.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 08:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
