Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 11-09-2012, 04:57 PM   #1
laminate flooring
can Redgard be used on a concrete floor on which laminate flooring will be installed?
talullah is offline   Reply With Quote
Old 11-09-2012, 05:10 PM   #2
Rewards Points: 13,700
If the slab has a moisture issue then do not use laminite.
Laminites going to need a pad that has a vaper barrier on the back side any way so Red Guard would not be needed.
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 05:57 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
