Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 06:50 PM   #1
Laminate flooring
I have a room that is 13'8" x 20' and also I have a hall running off of that room that is 3' wide and 18' long. My question is which way looks the best running the fooring down the hall, horizontal or veridical?
RUN91 is offline   Reply With Quote
Old 08-25-2012, 08:57 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Laminate flooring
You will want to run it the longest way of the room, less wast. Offset your seams 12" and keep 1/4" perimitaer space between LAM & wall.
JetSwet is online now   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
RUN91 (08-26-2012)
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
