Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 06:59 PM   #1
laminate flooring
Our basement has a concrete floor..we are putting in a washroom and laundry room....we would like to have laminate flooring...how would we install.......
Kelley27 is offline   Reply With Quote
Old 06-11-2012, 07:35 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Bad idea. Laminate should not be used in a wet area.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-11-2012, 07:58 PM   #3
Rewards Points: 13,250
Concider sheet linolium, tile, almost anything but laminite.
I would not even use laminite in a basement. For the main floor I'd be using engineered flooring is you want a real wood floor.
Old 06-11-2012, 09:14 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Check the brand of laminate that you are interested in to see if they do state you can put it below ground level, some do some don't recommend it and will or will not void warranty.
Doesn't seem like you have water issues in the basement.
There really isn't anything wrong with having a washer dryer on a laminate floor,
JetSwet is offline   Reply With Quote
Old 06-11-2012, 10:14 PM   #5
Rewards Points: 216
yeah. until the washer leaks ....
Fix'n it is offline   Reply With Quote
Old 06-11-2012, 10:22 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
No floor is safe from that except tile, countless numbers of homes have washers on laminate floors.
Old 06-11-2012, 10:34 PM   #7
Rewards Points: 42
Just means there are a lot of people doing the wrong thing.
Old 06-11-2012, 10:37 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
And there's only one rusty baker. I don't like these numbers?!? Eeek! Lol
Old 06-12-2012, 07:23 AM   #9
Rewards Points: 42
You really think it's a good idea putting laminate in areas that usually get a lot of water on the floor, when water will ruin it? I don't.
Old 06-12-2012, 08:04 AM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
I wouldn't suggest it in a bathroom.
It's common sense not to leave wet cloths on a floor. Im not going to argue about what I see in homes and apartments as far as washer dryer on laminate floor.
Old 06-12-2012, 09:58 AM   #11
Rewards Points: 42
No difference than putting carpet in a wet area. You know it will fail, you just don't know when.
Old 06-12-2012, 06:12 PM   #12
Trucon01's Avatar
Rewards Points: 510
No one mentioned vinyl wood planks Wouldn't these be OK?
http://www.lumberliquidators.com/ll/...a7a517a39870e7
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 06-12-2012, 06:31 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
That's a option as well.
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
