Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2012, 09:35 AM   #1
Laminate Flooring
We just bought a house with open floor plan where existing laminate butts against carpet. I want to replace the carpet with laminate that matches the existing laminate. Is it possible to do this without having an obvious place where the existing laminate ended and carpet started. The plan is so open that a transition strip won't work.
aseymore is offline   Reply With Quote
Old 04-14-2012, 10:41 AM   #2
Rewards Points: 14,294
Depends, is there a transition strip there now?
Once it's removed did someone rip the laminite to width or is the T or G still there?
Are both subfloors level to each other?
Old 04-14-2012, 10:52 AM   #3
Rewards Points: 528
Depends on the overall length. if it is too long an expansion strip must be in there.
framer52 is offline   Reply With Quote
Old 04-14-2012, 06:09 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Joe is right, If it's not ripped on the side you need then it will work.
JetSwet is offline   Reply With Quote
Old 04-14-2012, 06:12 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
I have never heard of needing a transition piece if the room is too long.
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Laminate flooring and such for kitchen christineka Flooring 5 01-04-2011 07:08 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
