Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 12:44 PM   #1
laminate flooring
How does Mannington Diamond Bay Collection compare to other types of laminate regarding scratch resistance &, water damage, and does the company fare with respect to warranty issues?
floorchallenged is offline   Reply With Quote
Old 03-01-2012, 12:56 PM   #2
Rewards Points: 14,278
http://www.laminateflooringco.com/a-...c-ratings.html
Before buying anything also concider laying engineered flooring instead.
It's real wood, can be refinished, super tough finish coat on top, installs almost the same way.
Looks like real wood, not plastic, no hollow sound when you walk on it.
Will add value to the home, not lower it like laminite will.
Old 03-01-2012, 06:41 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Mannington is one of the more reliable brands out there for Laminate.
They are designed to be dent resistant and scratching as well although there are limits.
Over all it's better then P&S and vinyl but not as engineered hard wood.
Most people choose lam because it's a cheap alternative to hardwood.
JetSwet is offline   Reply With Quote
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 05:57 AM
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
