Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 07:36 PM   #1
Laminate Flooring
We want to change the flooring in our living room to a laminate. It is next to our kitchen separated by walls & an arch-way entrance. My kitchen has a light oak laminate that is about 10yrs. old. Trying to match it is impossible. My question is whether or not it is "acceptable" to pick a different color laminate for the living room, such as one that is darker? I have been told 2 different things. One is that this is totally ok & the other of course is that this would be a huge mistake. I am trying to clarify whether or not this is a good option or should we just stick w/ carpet.
K Gray is offline   Reply With Quote
Old 07-15-2011, 09:44 AM   #2
Solid Acacia Plank
SuperFloor's Avatar
It is acceptable to put a different colored wood in a connecting room. To help it look better you can put a coordinating t-mould in that archway to create a separation between the rooms.
A darker color would probably compliment a lighter color, but you really aren't limited by the flooring in the kitchen. Style your home for you!
SuperFloor is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 05:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
