Laminate Flooring ... - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 02:13 PM   #1
laminate flooring ...
My landlord said when they installed the real wood flooring over concrete foundation in the living room, they had to level the floor first by putting something down like concrete ... I am about to pull up the carpet in the master and study and lay laminate flooring ... do I need to worry about leveling the floor? Do I need to put down a moisture barrier? The laminate already has padding ... do I need to add an underlayment?
Last edited by Ramona62; 05-06-2011 at 02:16 PM. Reason: quotation marks not right around word level
Ramona62 is offline   Reply With Quote
Old 05-06-2011, 07:10 PM   #2
woodman58's Avatar
The floor needs to be flat, not level, to put laminate on it. You do need a moisture barrier. You do not need an underlayment.
woodman58 is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 02:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 12:04 PM
