-   -   laminate flooring ... (http://www.diychatroom.com/f5/laminate-flooring-103763/)
Ramona62 05-06-2011 03:13 PM
My landlord said when they installed the real wood flooring over concrete foundation in the living room, they had to level the floor first by putting something down like concrete ... I am about to pull up the carpet in the master and study and lay laminate flooring ... do I need to worry about leveling the floor? Do I need to put down a moisture barrier? The laminate already has padding ... do I need to add an underlayment?
woodman58 05-06-2011 08:10 PM
The floor needs to be flat, not level, to put laminate on it. You do need a moisture barrier. You do not need an underlayment.
