Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 07:29 PM   #1
PLH
Laminate flooring
I'm installing Pergo laminate and don't want to remove the thin, very flat, no nap indoor outdoor carpet that is very tightly glued to a cement floor. Can I put the Pergo right on top of the carpet?
PLH is offline   Reply With Quote
Old 04-18-2011, 08:55 PM   #2
Rewards Points: 262
According to their literature "carpet and pad must always be removed." It goes on to say "If there is any question about the suitability of the subflloor... Contact Tech support at 1-800-33-PERGO"
Most likely you will void the warranty if you install it that way.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
PLH (04-19-2011)
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
