Laminate Flooriing - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 10:26 AM   #1
Laminate Flooriing
We are considering laying laminate flooring in a basement over existing ceramic tiles. Rather than using the thin underlay suggested with laminate, would 1/2" styrofoam taped at joins with tucktape work? We are worried about moisture buildup under the styrofoam if it wasn't able to breath. At present, on high humidity days the tile does get a thin layer of moisture in places.
MacfadyenM is offline   Reply With Quote
Old 08-17-2012, 10:16 PM   #2
Rewards Points: 14,000
If there's that much moisture then no form of flooring is going to hold up.
Have you been running a dehumidifier?
May want to buy a barometer. It should be about 40 to 50 % or less.
A lot of laminites are not even below grade rated.
Use engineered flooring instead, it's far more stable.
But you have to find out where that moisture is coming from first/
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 12:43 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
