Laminate Floor - Wide Expansion Gap. - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 08:39 AM   #1
Laminate floor - wide expansion gap.
What do you do when you have a wider than expected expansion gap?
This is the first time I installed a laminate floor and as a first timer I made quite a few mistakes. One of them is not cutting the planks straight (I used a jigsaw). Well some turned out curved. Some of those planks have a gap wider than 1/4". But since my baseboard is quite thick I believe they can be covered. But I wonder if they can cause problems later on. If so then how can I fill those gaps?
Thanks.
altonhernandez is offline   Reply With Quote
Old 07-27-2010, 08:53 AM   #2
It will only cause ascetic problems. If the gap is slightly (1/8") showing I would put a small shim behind the baseboard in that spot. The gap at the top of the baseboard can be filled with painters caulk and looks better than a gap on the floor. If it is bigger then consider putting down qtr. round. Most lumber yards have 3/4" qtr round and that will give you atleast 1 1/4" or so of cover up. You can do the same shim trick with the qtr round too it you really messed your cuts up.
FlooringDude is offline   Reply With Quote
The Following User Says Thank You to FlooringDude For This Useful Post:
altonhernandez (07-27-2010)
Old 07-27-2010, 09:03 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
Just make sure you fasten the 1/4 round to the base, not the floor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
laminate room transition - expansion joint req'd? rtoni Flooring 9 06-02-2010 10:19 AM
Laminate Expansion Gap & Room Size BataviaJim Flooring 7 03-25-2009 06:50 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
