Old 12-10-2012, 12:58 PM   #1
laminate floor- what's the verdict?
I know you are not supposed to install cabinets over a floating laminate floor- but how about installing under refrigerator and stove?
Huskyfan68 is offline   Reply With Quote
Old 12-10-2012, 01:18 PM   #2
Pro Flooring Installer
rusty baker's Avatar
People do it all the time. But you know that laminate in a kitchen is a bad idea. Any moisture and the particle board backing will fall apart.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-10-2012, 01:51 PM   #3
I have it in the kitchen and it's under the fridge and stove.
I haven't had a problem due to moisture but I have had a problem with a few of the joints popping open and it has been sticky in one area since it was new. There have been spills and we just wipe it up right away so it hasn't done any damage.
I wouldn't recommend it for any area :-)
msaeger is offline   Reply With Quote
Old 12-10-2012, 02:08 PM   #4
Old 12-10-2012, 05:36 PM   #5
Plus the loaded fridge is a pretty heavy item to sit on laminate day after day after day. Especially if it is sitting on the 4 little wheels so you can pull it out.
ToolSeeker is online now   Reply With Quote
Old 12-10-2012, 05:40 PM   #6
Having the refrigerator and or stove on a laminate floor will not hurt it in any way. As long as you leave spacing around the perimeter it will be ok.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
ToolSeeker (12-10-2012)
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
