Old 02-12-2008, 01:01 PM   #1
Smile
Laminate floor underlayment Question
Greetings! I'm putting down Swiftlock Plus, laminate flooring in my living room. The flooring will be installed on top of concrete. The flooring I bought has a underlayment pad preattached to the back of each board. Since it is being installed over concrete I was thinking of putting down a traditional vapor barrier with underlayment pad underneath the flooring as well to give the floor a little extra give. This would give it two layers of pad underneath it. My question is... is it a mistake to do this? Would 2 thickness's of pad be to much? make the floor to spongy? An thoughts would be appreciated. Thanks
toolman33 is offline   Reply With Quote
Old 02-12-2008, 03:36 PM   #2
Tileguy
Bud Cline's Avatar
You should check with the flooring manufacturer on that one. Too much padding certainly could be an issue.
Old 02-12-2008, 07:39 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I wouldn't suggest putting 2 layers of padding down. If anything, consider installing a 4 mil Poly layer (vapor barrier) over the concrete.
- Build Well -
Old 02-12-2008, 07:53 PM   #4
newer than a newbie...
If you feel that the concrete is cold on your feet (really cold), I would personally put the vapour barrier or any other layers that can warm things up.
Following the advice of 'experts' at some big box stores, they suggested I wouldn't need a vapour barrier below my laminate that I installed on a bedroom above a cold porch. I did install a 'foam type' of padding, but cold air still comes in very easily - the vapour barrier would've helped at least cut the wind-chill down in cold weather.
I'm not a pro-expert, but I would put the vapour barrier down.
mcvane is offline   Reply With Quote
Old 02-12-2008, 08:10 PM   #5
Thank you for your thoughts, I think I am just going to go with a vapor barrier and just use the padding thats on the back of the boards. I would hate to have to rip the floor up because it was too spongy to walk on.
Laminate in Basement Question atilla137 Flooring 16 11-10-2007 08:44 PM
Ready to lay laminate... Question... KUIPORNG Flooring 6 04-13-2007 03:17 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 11:48 PM
Laminate Flooring Question cacell Flooring 6 03-03-2006 06:44 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
