Old 03-08-2007, 04:11 PM   #1
laminate floor underlayment installation?
do I need to glue the underlayment to the OSB board subflooring? before laying glue-less laminate? or do I can also flow it there...? when laying underlayment, do I let the face with waterproof membrane facing down or facing up as the type I purchased is with a waterproof membrane foam type... and when the underlayment meet the wall, do I make it a bit more so that all laminate can seat on it at edge and then I can cut out extra by utility knife...? thanks for answering....
KUIPORNG is offline   Reply With Quote
Old 03-08-2007, 06:52 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Kui****g:
No, don't glue the underlayment down. Let it lay were it is laid, the edges meeting each side of the underlayment should be 'taped' to each other, unless they have a factory way of adhering edge to edge.
Water proof membrane always face down.
Where the underlayment meets the wall; yes you could butt it there and cut the excess out to get a snug fit.
- Build Well -
Laminate floor installation price mt232 Flooring 24 11-05-2011 11:35 AM
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
