Laminate Floor And Underlay - Flooring - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 09:27 PM   #1
Rewards Points: 30
Laminate floor and underlay
I'm going to replace a carpeted area with laminate floor. I just pulled up the carpet and left the underlay. Is it possible to reuse the carpet underlay for the laminate flooring? Or will I need to change the underlay and get the laminate floor underlay?
The underlay is not that thick (maybe around 3-4mm I'm guessing) and it is relatively clean.
Just looking for a second opinion.
sleong is online now   Reply With Quote
Old 10-01-2012, 09:48 PM   #2
Rewards Points: 12,868
Not the same density, the floor will flex to much and loosen up the seams.
If you buy better laminite it will have the padding built in.
