-   -   Laminate floor and underlay (http://www.diychatroom.com/f5/laminate-floor-underlay-158631/)
sleong 10-01-2012 08:27 PM
I'm going to replace a carpeted area with laminate floor. I just pulled up the carpet and left the underlay. Is it possible to reuse the carpet underlay for the laminate flooring? Or will I need to change the underlay and get the laminate floor underlay?
The underlay is not that thick (maybe around 3-4mm I'm guessing) and it is relatively clean.
Just looking for a second opinion.
joecaption 10-01-2012 08:48 PM
Not the same density, the floor will flex to much and loosen up the seams.
If you buy better laminite it will have the padding built in.
