Laminate Floor Through Doorway - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 06:18 AM   #1
Enormous Member
skipjack's Avatar
Rewards Points: 87
Question
Laminate floor through doorway
Hey guys... s'been a long time since I've been on here.
Anyway.. I'm installing several rooms of laminate flooring for a friend and am trying to figure out how to keep it all contiguous. It's a small house and I'm doing 2 bedrooms, a livingroom, and a hallway... oh.. and a couple small closets (ugh... forgot about those).
I was lying awake just now trying to visualize how to get the planks under the jambs and continue the planks from room to room.
Anyone have any tricks to pulling this off?
skipjack is offline   Reply With Quote
Old 05-06-2011, 06:51 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
That's really not a good idea. Floating floors like that are generally recommended to have each room split into it's own plane. A closet on the side would be fine, but rooms off a hallway for example should have a tmold at the doorway. If you try and run the whole house as one contiguous plane you are creating too many point where it can bind if it shift too much.
Darkling Designs
poppameth is offline   Reply With Quote
Tags
jambs , laminate flooring , transition
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Laminate positioning in doorway Dennish Flooring 1 02-27-2010 04:50 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
