Laminate Floor Layout - Flooring - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 02:32 PM   #1
pantuso
Laminate floor layout
I'm laying a 8mm, with underlayment laminate floor. The problem I'm having is the hallway. the hallway is L shaped. The first leg is 47 inches by 268 1/4 inches and the second leg is 47 inches by 157 1/4 inches long. The laminate is 7 5/8 inches wide by 48 inches long. If I use full planks I have 1 1/2inches left over at the edge. This is a very thin plank and I believe this will be problem in the future. Do you have any suggestions as to how to lay this floor? I have divided the plank by the 47 inches to allow 4 inches at the end of each run. My real problem is the turn of the L shaped hallway, due to the 4 inch plank. Other than a " tee moulding" does anyone have any suggestions? Thanks for your input...
pantuso is offline   Reply With Quote
Old 02-25-2011, 02:37 PM   #2
Steeler99's Avatar
split the difference....rather than use 6 full planks and a little of a seventh....start with a half plank rather than a full plank. Basically centering the pattern on the space rather than working off of one side with a full plank
Steeler99 is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 12:43 PM
Can't decide: Laminate or Engineered? rogersmj Flooring 7 08-30-2009 08:10 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
