Old 10-21-2010, 08:54 AM   #1
Question
Laminate Floor and Island
I will be installing a laminate floor in the kitchen and also adding an island.
I have talked to the people at the big box stores on whether to install the island on top of the laminate floor or lock down the island to the sub floor and then cut the laminate around it. Thought everyone would say cut around it, but, all 3 said to lay the laminate and then anchor the island through the laminate into the subfloor.
Are they correct? The kitchen is 12' X 12' so it's not real big. Doesn't putting the island on top of the laminate defeat the purpose of a "floating" floor?
Any advice is appreciated.
Don
donb98 is offline   Reply With Quote
Old 10-21-2010, 04:59 PM   #2
Tileguy
JazMan's Avatar
Don,
Go to the head of the class since you know more than those nice people who wear vests. Darn....it happens all the time.
You may also want to consider adding some added support to the joists under that new island if you have access.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
