Laminate Floor Installation ??? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 11:35 AM   #1
Question
laminate floor installation ???
Hi, I will be installing a glueless laminate floor in my house. The problem comes in where the hall runs a short distance off the living area then then forms a tee with 1 bedroom a short distance and 2 other bedrooms a greater distance in the other direction.
Dilemma; Not matter how I lay the flooring in the living room I am going to wind up with the flooring in one of the halls running crosswise with short lengths of flooring which I don't think looks right OR I will wind up with at least 1 transition strip in the hall, I don't like this option either.
I don't mind putting transition pieces from the hall into the bedrooms but I would rather have a seamless surface throughout the living room and halls.
Any thoughts???
Sorry this is long and somewhat convoluted, any help would be greatly appreciated, thanks, Magnolia
magnolia44 is offline   Reply With Quote
Old 08-06-2009, 12:12 PM   #2
Floorwizard's Avatar
To be able to click them together without a transition, you will need to start your rows with the groove side facing towards the hall wall, that way when you get to the smaller hall opening, you can click it to that piece after changing the direction of the lam.
Tough to explain without drawing a pic.
Floorwizard is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 06:05 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
