Laminate Floor Install - Advice? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 02:45 AM   #16
Originally Posted by MTN REMODEL LLC View Post
Tacoma..... Intereesting thought.... glueing vapor barrier down.... what are you accomplishing in doing so..... wouldn't it be alot of $10 sparay cans also.
Maybe worth it, just not sure what we're accomplishing?
TIA
Best
Funny as a professional you would ask in such a way , so I guess you opened the can here.
You would stick the corners to the concrete so you can pull it straight easier and with less time , Or you can Put a weight on the corner , Then move the weight and install the flooring , I don't mean glue the whole thing down , I am a pro ,If theres an easier faster way you don't know of ,just ask me ! Any other advice you need feel free , im one of the best fastest and most efficient , Genius idea , stick it once and lay the floor ,,, Or fiddle with it numerous times , You choose ,
tacomahardwood. is offline   Reply With Quote
Old 06-28-2013, 12:20 AM   #17
spray the corners . Use the rubber cement to hold the vapor barrier tight
Old 06-28-2013, 11:33 AM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,860
Tacoma.... I have no idea as to your comment above... I thought I was polite, and not looking to open any cans (except this PBR).
If it works for you great... whatever floats your boat...ah meant floor.
Take care
MTN REMODEL LLC is offline   Reply With Quote
Old 07-02-2013, 01:18 AM   #19
help i put laminate wrong did not stagger
i got to comfortable with doing first project. lock laminate in did check my staggering have row that is not stagger . is there any way of removing laminate with tearing it up
mik702mel is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 02:25 PM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 07:07 AM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Laminate Flooring - Newbie Trishl Flooring 9 04-21-2006 11:20 PM
