Laminate Floor Direction In An L Shaped Space - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2008, 09:35 PM   #1
Laminate floor direction in an L shaped space
I want to install laminate floor (tongue and groove) in my new home...here is my dilemma...I have a hallways which leads into the main living area which is L shaped...I want to change directions at the intersection...is that possible with a floating floor?
yesicamiranda is offline   Reply With Quote
Old 12-05-2008, 04:19 AM   #2
You could run a T-moulding from the inside corner to the outside corner of L. Why do you want to change directions?
T-Molding
“T-molding" is another common transition molding. T-molding is used to transition from one floor to another when both are at the same finished height. For example, if you installed laminate flooring in your living room and hallway, and later decided to install it in the bedrooms, then T-molding would be used to join the new laminate flooring with the previous installation. Another example would be where a new laminate or wood floor joined a ceramic tile floor at the same finished height. As you can see from the illustration, T-molding gets its name from its shape. Also note that the lip on each side of the T-molding is supported by the flooring. That is why it is important that both floors are at the same finished height. Any height variation between the two could cause the lips could snap off. Additionally, it is important to make sure there is adequate expansion space between flooring edges joined by the T-molding. The purpose of the extended lips is to cover the expansion space without interfering with the function of the space.
jerryh3 is offline   Reply With Quote
Old 03-17-2011, 11:57 PM   #3
Wood Worker
RiverOaks's Avatar
yes it can be done.. and I have done it and seen it.. how good are you with a router?
RiverOaks is offline   Reply With Quote
Old 07-16-2011, 08:53 PM   #4
Rewards Points: 111
I have the same question. I understand jerryh3's suggestion.
Riveroaks, could you elaborate on yours?
suncowiam is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
