Laminate Floor On Concrete. - Flooring - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 06:11 PM   #1
Question
Just looking for some opinions on installing laminate flooring on top of concrete. I will be using a good underlay with a vapor barrier built in. Let me know what you think? Is the floor going to be too cold? Am i going to be tearing it back up 2 years from now ?
mj876 is offline   Reply With Quote
Old 03-08-2010, 01:40 PM   #2
We had laminate installed in our living room over a concrete slab.
Installer used that blue underlay material.
We're in SoCal.
The floor is very comfortable to walk on in bare feet. I doubt cold would be an issue for you, unlike ceramic tile.
Oakstable is offline   Reply With Quote
Old 03-08-2010, 01:59 PM   #3
depending on where you are and the condition of the concrete floor. If there are insulation beneath the concrete floor then you're probably okay, but if there's not then its not. How big is your living room? Its a bit hard to get a perfectly flat concrete pour so you want to make sure that there isn't any dips as even a 1/4" dip (you will not see it just by looking) will create a creaky spot that will annoy you to no ends.
Frostbite is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 05:47 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
Tile over very old laminate secured to concrete? B Parker Flooring 13 03-30-2008 03:15 PM
