Laminate Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-20-2007, 12:49 PM   #1
Laminate floor
Can anone tell me the best way to lay laminate floor planks and which is the best way to start i.e half plank etc?
gav2611 is offline   Reply With Quote
Old 12-20-2007, 01:20 PM   #2
Remodeler
MinConst's Avatar
You want to lay a full length along a wall where your going to start. See if you end up with at least 1/2 a plank at the end. You don't want a little piece. Adjust to make sure you have a good size plank at the end. From that point start with the piece you figured out above and the next one cut that 1/2 of that or longer. Just keep the ends stagered.
If you can start with a full one, use it to start then 1/2, then full, then 1/2 etc.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 12-21-2007, 05:04 PM   #3
Floorwizard's Avatar
Usually run the lengths of the boards parallel to the longest wall.
generally.
Floorwizard is offline   Reply With Quote
Old 12-22-2007, 10:34 AM   #4
Lawn Care/Handyman Serv.
generally.
That's what I've always seen/heard on diy tv/forums. Having never done it myself (plan to in the near future), my first instinct would have been to lay the boards perpendicular to the floor joists and make sure to hit each joist with a nail??? Seems like that would make a more solid (less apt to squeek) install?? Am I wrong?
Thanks,
Dave
EZ Rider is offline   Reply With Quote
Old 12-22-2007, 06:33 PM   #5
Remodeler
MinConst's Avatar
Laminate floors float. No nails. What are you nailing down a subfloor before the lam?
Web
One Man Shops
Old 12-22-2007, 07:09 PM   #6
that statement would be correct for a nail down wood.
not a lam.
which is it?
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Water damage below laminate floor ediconu Flooring 10 01-23-2012 12:19 PM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 04:06 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 08:07 AM
Horizon Laminate Floor from China Kelvestto Flooring 3 09-19-2006 11:19 PM
