Laminate Cutter? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 04:30 PM   #1
Laminate cutter?
Hi
Has anyone used this tool before? I am really eager to start planning laminate-flooring my kitchen floor, but am nervous about the cutting. If this tool works as well as the video shows, then I dont have to deal with the electric saw and stuff.
thanks
Sam
emperor_black is offline   Reply With Quote
Old 07-14-2009, 05:20 PM   #2
Looks like it would be a great idea if it actually lasted. I just laid some laminate and it is such a blade destroyer!
Justin08 is offline   Reply With Quote
Old 07-15-2009, 01:31 AM   #3
so, what's the best laminate cutter that I need to get? Do I need to get one of those wood cutters that mount on a table or something?
Old 07-15-2009, 05:58 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
We have one of these at the store. We've used it for years and it still works like a champ. Our doesn't extend as far as that one. It's got a fixed fence so you can only cut boards up to about 9". Even this one cost over $300. It does save a lot of time and saves you a bundle on saw blades.
poppameth is offline   Reply With Quote
Old 07-15-2009, 09:24 AM   #5
TooledUp
If you have a Rotozip tool there are bits designed for cutting laminate. I guess the only draw back would be how straight you need your cut unless you have something to mount the tool to. The bits themselves are pretty cheap, XB-LF1 for a 1-pack and XB-LF5 for a 5-pack. If you need more info let me know.
TooledUp is offline   Reply With Quote
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 01:18 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Best quality underpad to use for laminate?? sillysimms Flooring 4 07-27-2011 05:05 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
