Laminate On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 09:53 AM   #1
Laminate on concrete
I'm lookin to put some laminate flooring on the concrete floor of my basement. I was advised by the carpet layer who is doing the carpeting down there to put vapor barrier under the laminate. My question is does this laminate need glued to the concrete or can it float. I will be using 6 mil plastic as barrier. This is a 100 sq foot area and the basement is dry.
c47205 is offline   Reply With Quote
Old 01-08-2014, 10:24 AM   #2
Trucon01's Avatar
Rewards Points: 510
I was thinking of doing the same thing, but was advised not to. The basement is dry now, but who knows what can happen. Have you looked at the vinyl plank flooring, which has a similar look?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 01-08-2014, 10:35 AM   #3
Rewards Points: 12,790
Both can have issues.
Some laminates will fail after a single water event.
One leaking pipe, high humidity, wax ring leaking, washing machine over flows and there trash.
There's about 1000 post on this and just about any DIY site talking about installing over a slab and finding mold growing under it.
If your going to do it I'd suggest using a product like Dri-Core under it as a subfloor.
Laminate can not be attached to the floor in anyway! It's never glued down.
If you did all the seams would open up from trying to expand and contract.
Old 01-21-2014, 10:54 PM   #4
Rewards Points: 27
Check out the January 2014 postings on the Allure flooring thread. Their provide criteria. After reading that, if doing it again, I would lay down and tape the poly moisture barrier whether or not my basement was bone dry - just to "future proof" it. I'm very happy with the allure.
KinNorth is offline   Reply With Quote
Old 01-22-2014, 07:15 PM   #5
Registered User
Rewards Points: 4,888
If in a cold climate or near a daylight basement wall, the springtime moisture could condense on the backside of laminate flooring to mold; http://www.buildingscience.com/docum...bef2a9fb9809f2
http://www.epa.gov/athens/learn2mode...enrys_map.html
http://nsidc.org/fgdc/maps/gtmap_can_us_browse.html
That is where XPS and plywood will out-perform the Dricore product; it also insulates and stops room condensation.
Gary
Old 01-22-2014, 07:35 PM   #6
Pro Flooring Installer
rusty baker's Avatar
To be fully prepared, read all the threads about the failure of Allure, too.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-22-2014, 08:28 PM   #7
Rewards Points: 27
Gary
The thing is, wouldn't mould form on the underside of any vapour barrier laying on top of the concrete (if the moisture can't evaporate and escape into the room)?
The Drycore only provides about 1" of foam insulation would that be enough?
Wouldn't a concrete sealant, or a coat of varnish or something seal out all moisture?
Old 02-22-2014, 09:18 PM   #8
Floors can not be water proofed from the topside.
rusty baker (02-22-2014)
Old 02-22-2014, 10:04 PM   #9
Absolutely right.
stinky concrete and laminate flooring princessupdo Flooring 3 08-11-2010 12:19 AM
radiant heat under laminate...over concrete? gone_fishing Flooring 2 03-18-2009 06:39 PM
concrete basement - installing laminate on delta SDG Flooring 1 12-29-2008 09:10 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
