Laminate/Carpet Transition On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 08:57 AM   #1
Laminate/Carpet transition on concrete
I am in the process of finishing my basement, the room is 13 x 36 with 2/3 of the flooring a laminate and the other carpet. In reading various tutorials on carpet installation this seems fairly straight forward; glue/nail tacklees carpet strips to the perimeter, breakout the knee kicker and stretcher and follow the normal process.
But I am unsure of what to do on the 13' length that will meet the laminate. I have read that you should not use tackless strips in doorways and areas where there will be foot traffic because eventually the tacks will work thru and poke peoples feet.
Suggestions?
mmazour is offline   Reply With Quote
Old 04-13-2010, 09:27 AM   #2
Remodeling Contractor
use the transition strips that are made for carpet to laminate transition from the flooring supply to match your laminate floors. These cover the edges of the carpet and the wood but still allow the wood to move as required under these strips.
Old 04-13-2010, 11:35 AM   #3
How should the carpet be attached to the floor at the transition? Do I just use regular tackstrips for the carpet in that area and rely on the transition piece to cover the tackstrip?
Old 04-13-2010, 12:10 PM   #4
the carpet side of these strips have built in nails to hold the carpet and then the metal gets tapped over to cover them. On the laminate side it has a groove to allow the wood to slide in and still move.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
