Laminate Bowing - Flooring - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 12:03 PM   #1
Rewards Points: 141
Laminate bowing
I am on the 3rd row of planks (19 feet in length) and noticed the center is nearly a half inch spacing from the wall, while the ends are still close to a 1/4 inch spacing. I remember reading somewhere why this happens. But I cannot find it again.
How can I fix this?
sen2two is offline   Reply With Quote
Old 12-30-2011, 01:02 PM   #2
DIY staff
Rewards Points: 7,174
Have you discovered a bowed wall or is the flooring getting a 'belly'
If 'bellying' Block both ends so they can't move--then drive the center of the belly back to the wall--using a scrap of flooring and a hammer---(use a string line to check your progress)
Let's see what others suggest
Old 12-30-2011, 04:21 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You would be well served to place spacers at each slat joint along the beginning wall so that you can keep everything in check as you go. If the wall is bowed then you will have to adjust for it.
Now is the time to know if the wall is bowed before you go any further. You can use a string line to find out.
XXX
Old 12-30-2011, 04:41 PM   #4
Rewards Points: 13,694
Is there 1/2 spacing in the middle on both ends of the run or tight on one side and 1/2" on the other, as if something moved?
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 07:38 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
