-   -   Laminate in Basement Question (http://www.diychatroom.com/f5/laminate-basement-question-8142/)
atilla137 05-01-2007 08:47 PM
I installed a laminate floor in my basement and I want to put down the metal strips that bridge the gap between the laminate and carpet.
How do I attach the strips to the concrete floor? There are some small screws that come with the srip.
I looked at some lead plugs at Home Depot but they were way too big.
Thanks for any help
send_it_all 05-02-2007 12:58 AM
Rent a concrete hammer drill if you dont have one. Home D poe sells some little green plastic sleeve anchors that will accept a wood screw. You'll have to drill several 1/4" holes in the concrete after you use the metal strip to lay out and mark the screw location. There are also actual anchors that they sell specifically for door thresholds, but they might be a bit large for what I'm picturing this metal strip to be.
KUIPORNG 05-02-2007 08:40 AM
Why use metal strip? rather than transition strip specific for the laminate.. that they have very nice clean way of installing... they may not be as strong as metal strip... but for sure will look better.... I think they are strong enough for home use as it's been use everywhere...
send_it_all 05-02-2007 10:52 PM
you still need to screw down the plastic track for the laminate transition using the same method of anchoring. same thing
Floorwizard 05-03-2007 12:40 AM
I have seen liquid nails without the track being used all the time.
works just fine. just make sure you only glue to substrate.
send_it_all 05-03-2007 12:48 AM
I would no do this on a bare concrete basement floor with no underlayment/vapor barrier beneath the strip. And obviously I wouldnt glue the strip to underlayment...so looks like I'm breaking out the drill.
Floorwizard 05-03-2007 12:53 AM
o.k. then
KUIPORNG 05-03-2007 08:42 AM
It is not the same thing
because you can hide the ugly screw underneath and use tapcon screw in this case or some screws you found from your grandfathers toolbox....
where when you use metal strip... you care about the appearance of the screws....
peter1 05-03-2007 10:45 AM
1 Attachment(s)
Actually there's a special plastic screw/plug for this purpose. It slides neatly into the channel on trim/profile, no ugly screw heads, doesn't require plastic sleeves, and no tracks. It measures about 6.5mm in diameter, so just drill a 6mm hole then press it in.
The offset on the screw allows it to correctly position itself if the holes don't line up perfectly. See picture for illustration.
KUIPORNG 05-03-2007 11:50 AM
yes good invention, except you need to go to that single store in the whole country to get it...
peter1 05-03-2007 06:47 PM
What are you talking about? Contact the distributor to find the stockists:
http://www.robertsconsolidated.com/
KUIPORNG 05-04-2007 08:25 AM
Practically, if small items like that cannot be obtained from the big store around the corner... it is a harsel to home owner... but I am sure some home owner will go that far a way to get small things like that... I still have problem getting my PC nailer fuel cell which is a much more common item... not to mention go through the hassel to obtain a transition strip... to be honest... if things not sold in HD... many general people like that is ... we try to find replacement at HD to save the driving/headache...etc. that is why stock price of HD is sky high... it offers convenience other cannot...
MattCoops 05-06-2007 01:13 PM
HD also sells concrete nails that you can nail a transition strip in with
you can put away the drill:thumbsup:
Genoskate 10-21-2007 08:02 AM
why ?
Get those blue screws meant just for concrete that comes with the drill bit and fill em in with wood filler.
Darylh 10-21-2007 10:55 AM
I use a hammer drill and glue in 1/4" wood dowels.
