Old 10-12-2007, 09:38 AM   #1
Laminate in Basement over Hydronic Radiant Heat
Hello,
I am in process of rebuilding a newly purchased house.
I installed hydronic radiant heat in the basement, which is covered with concrete. I am planning to install floating hardwood floor (DuPont is one of my options) over the concrete and have couple of questions:
1. How damaging is water to floating hadwood floor in the event of a flood. I had to experience it yesterday and now not so sure about hardwood in the basement anymore.
2. Also, is installing hardwood, although engineered, over hydronic radiant heat practical? If so, can I install underlayment padding under hardwood?
Any suggestions would be greatly appreciated.
Thanks,
Art.
art2670 is offline   Reply With Quote
Old 10-12-2007, 12:06 PM   #2
Thanks,
Art.
Any type of wood floor will get damaged by water/flood.
How hot does your radiant get?
redline is offline   Reply With Quote
Old 10-12-2007, 04:27 PM   #3
I have yet to test the system. It has been recently installed. What is the criteria, so that I may ask my plumber?
Old 10-12-2007, 11:17 PM   #4
Floorwizard's Avatar
With any radient heat system you still want to lay a pad to float over. Whatever the manufacturer sells.
The most important part will be to make sure the humidy level stays in the 35% range. The heat will dry out the wood, and you will be doing it a big favor by giving it some moisture.
Floorwizard is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 01:52 PM
Radiant heat under laminate sierraac Flooring 2 08-21-2007 01:43 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 12:33 PM
