Laminate In Basement? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-13-2008, 07:25 PM   #1
Rewards Points: 24
laminate in basement?
I would like to put laminate flooring in a finished basement. What is the correct way to do this as far as a vapor barrier? Thanks
ponch37300 is offline   Reply With Quote
Old 04-14-2008, 05:44 AM   #2
Rewards Points: 150
Umm, use one
mike costello is offline   Reply With Quote
Old 04-14-2008, 10:00 AM   #3
Rewards Points: 24
Thanks. What do you recommend for a vapor barrier, just plastic? How thick? Should i seal the cement or do anything to it before the vapor barrier? Thanks again.
Old 04-14-2008, 06:47 PM   #4
Rewards Points: 150
Lol sorry ,couldnt resist.
Just read the install specs on your specific laminate. They will tell you what mil plastic to use or have an underlayment with a moisture barrier built in.
Sealing your floor wont help ,but you want to know the moisture content of your slab before you do anything.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Laminate in Basement Question atilla137 Flooring 16 11-10-2007 07:44 PM
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 10:17 PM
