-   -   laminate in basement? (http://www.diychatroom.com/f5/laminate-basement-19875/)
ponch37300 04-13-2008 07:25 PM
I would like to put laminate flooring in a finished basement. What is the correct way to do this as far as a vapor barrier? Thanks
mike costello 04-14-2008 05:44 AM
Umm, use one
ponch37300 04-14-2008 10:00 AM
Thanks. What do you recommend for a vapor barrier, just plastic? How thick? Should i seal the cement or do anything to it before the vapor barrier? Thanks again.
mike costello 04-14-2008 06:47 PM
Lol sorry ,couldnt resist.
Just read the install specs on your specific laminate. They will tell you what mil plastic to use or have an underlayment with a moisture barrier built in.
Sealing your floor wont help ,but you want to know the moisture content of your slab before you do anything.
