Laminate In Basement - Flooring - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 06:20 PM   #1
laminate in basement
what should go under the laminate in a basement
jan edman is offline   Reply With Quote
Old 07-26-2012, 06:21 PM   #2
Rewards Points: 528
Nothing aS laminate is not good for below grade applications., sorry.
framer52 is offline   Reply With Quote
Old 07-26-2012, 06:31 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
You will have to get below ground rated laminate.
If so and you don't have any water issues then a 6 mil polyethylene moisture barrier directly to the concrete.
JetSwet is offline   Reply With Quote
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Install swiftlock plus laminate flooring on a concrete basement Rdavoodi Flooring 1 10-13-2011 03:00 PM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 12:58 PM
Laminate on basement floor, but there is a drain there nag Flooring 6 06-10-2010 08:59 PM
Laminate in Basement Question atilla137 Flooring 16 11-10-2007 07:44 PM
